Hi, I’m trying to set up a voucher generating system using the above mentioned router coupled with Mikhmon. The issue I’m having is with the hotspot I’ve configured in the IP interface. After configuration, the hotspot is marked as “Invalid”. All other configurations I’ve added in Winbox work perfectly well. Does anyone have an idea of how I can resolve this issue?
The question is not very meaningful when you do not mention the RouterOS version you are using.
@MikroTikNewbie1 You wanna play with vouchers… you are gonna have to provide the ENTIRE config. and whatever service generated the vouchers for you.
