RB951 under CAPsMAN only 270Mbps
I’ve just found something I’m not able to explain myself. If I setup RB951 (RB951Ui-2HnD ROS 6.33.3) as AP bridge, band 802.11b/g/n 20/40 channel, WMM enabled, open security profile, all rates in default - as well as MCS, HT chains 0+1 RX and TX, GI any - it’s max speed is advertised as 300Mbps (= MCS15, 40MHz channel, short GI). When I untick all to MCS14, it goes down to 270Mbps, when GI changed to long - to 243Mbps - so far so good.
But if I connect this AP to CAPsMAN node - wher I have this configuration
name="cfg" mode=ap ssid="our_SSID" max-sta-count=25 multicast-helper=default tx-chains=0,1,2 rx-chains=0,1,2 guard-interval=any country=czech republic security=radius datapath=wifi channel.band=2ghz-onlyn channel.extension-channel=eC
It’s going only to 270Mbps. As mentioned here https://en.wikipedia.org/wiki/IEEE_802.11n-2009 it’s MCS15, 40MHz channel with long (800ns) GI.
I’ve just checked it with LizardSystems WifiScanner and there is a difference in the HT capabilities fields:
300Mbps operation:
Information Elements: 12 (223 bytes)
SSID: Test-N-test
Element ID: 0 (SSID)
Length: 11 octets
SSID: Test-N-test
Supported Rates: 1 (B), 2 (B), 5.5 (B), 11 (B), 6, 9, 12, 18 Mbps
Element ID: 1 (Supported Rates)
Length: 8 octets
Basic Speed Rate: 1 Mbps
Basic Speed Rate: 2 Mbps
Basic Speed Rate: 5.5 Mbps
Basic Speed Rate: 11 Mbps
Speed Rate: 6 Mbps
Speed Rate: 9 Mbps
Speed Rate: 12 Mbps
Speed Rate: 18 Mbps
DSSS Parameter Set: Current channel: 5
Element ID: 3 (DSSS Parameter Set)
Length: 1 octet
Current channel: 5
Traffic Indication Map (TIM)
Element ID: 5 (Traffic Indication Map (TIM))
Length: 4 octets
DTIM Count: 0
DTIM Period: 1
Bitmap Control: 00000000 (0x00)
…0 - Traffic Indicator: No Group Frames Buffered at AP (0x00)
0000000. - Bitmap Offset: 0 (0x00)
Partial Virtual Bitmap: 00
ERP Information
Element ID: 42 (ERP Information)
Length: 1 octet
ERP Information: 00000000 (0x0000)
…0 - Non ERP Present: No
…0. - Use Protection: No
…0.. - Barker Preamble Mode: No
xxxxx… - Reserved
HT Capabilities
Element ID: 45 (HT Capabilities)
Length: 26 octets
HT Capabilities Info: 00010000 01101110 (0x106E)
… …0 - LDPC Coding Capability: Not Supported
… …1. - Supported Channel Width Set: Both 20 MHz and 40 MHz operation is supported
… …11.. - SM Power Save: SM Power Save disabled (0x03)
… …0… - HT-Greenfield: Not Supported
… ..1… - Short GI for 20 MHz: Supported
… .1… - Short GI for 40 MHz: Supported
… 0… - Tx STBC: Not Supported
…00 … - Rx STBC: No support (0x00)
…0. … - HT-Delayed Block Ack: Not Supported
…0.. … - Maximum A-MSDU Length: Not Supported
…0… … - Maximum A-MSDU Length: 3839 octets
…1… … - DSSS/CCK Mode in 40 MHz: STA uses DSSS/CCK in 40 MHz
..x… … - Reserved
.0… … - Forty MHz Intolerant: Use of 40 MHz transmissions prohibited
0… … - L-SIG TXOP Protection Support: Not Supported
A-MPDU Parameters: 00000011 (0x03)
…11 - Maximum A-MPDU Length Exponent: 65535 bytes (0x03)
…000.. - Minimum MPDU Start Spacing: No restriction (0x00)
xxx… - Reserved
Supported MCS Set
Rx MCS Bitmask
…1 - MCS Index 0: Supported (0x01)
…1. - MCS Index 1: Supported (0x01)
…1.. - MCS Index 2: Supported (0x01)
…1… - MCS Index 3: Supported (0x01)
…1… - MCS Index 4: Supported (0x01)
..1… - MCS Index 5: Supported (0x01)
.1… - MCS Index 6: Supported (0x01)
1… - MCS Index 7: Supported (0x01)
…1 - MCS Index 8: Supported (0x01)
…1. - MCS Index 9: Supported (0x01)
…1.. - MCS Index 10: Supported (0x01)
…1… - MCS Index 11: Supported (0x01)
…1… - MCS Index 12: Supported (0x01)
..1… - MCS Index 13: Supported (0x01)
.1… - MCS Index 14: Supported (0x01)
1… - MCS Index 15: Supported (0x01)
…0 - MCS Index 16: Not Supported (0x00)
…0. - MCS Index 17: Not Supported (0x00)
…0.. - MCS Index 18: Not Supported (0x00)
…0… - MCS Index 19: Not Supported (0x00)
…0… - MCS Index 20: Not Supported (0x00)
..0… - MCS Index 21: Not Supported (0x00)
.0… - MCS Index 22: Not Supported (0x00)
0… - MCS Index 23: Not Supported (0x00)
…0 - MCS Index 24: Not Supported (0x00)
…0. - MCS Index 25: Not Supported (0x00)
…0.. - MCS Index 26: Not Supported (0x00)
…0… - MCS Index 27: Not Supported (0x00)
…0… - MCS Index 28: Not Supported (0x00)
..0… - MCS Index 29: Not Supported (0x00)
.0… - MCS Index 30: Not Supported (0x00)
0… - MCS Index 31: Not Supported (0x00)
…0 - MCS Index 32: Not Supported (0x00)
…0. - MCS Index 33: Not Supported (0x00)
…0.. - MCS Index 34: Not Supported (0x00)
…0… - MCS Index 35: Not Supported (0x00)
…0… - MCS Index 36: Not Supported (0x00)
..0… - MCS Index 37: Not Supported (0x00)
.0… - MCS Index 38: Not Supported (0x00)
0… - MCS Index 39: Not Supported (0x00)
…0 - MCS Index 40: Not Supported (0x00)
…0. - MCS Index 41: Not Supported (0x00)
…0.. - MCS Index 42: Not Supported (0x00)
…0… - MCS Index 43: Not Supported (0x00)
…0… - MCS Index 44: Not Supported (0x00)
..0… - MCS Index 45: Not Supported (0x00)
.0… - MCS Index 46: Not Supported (0x00)
0… - MCS Index 47: Not Supported (0x00)
…0 - MCS Index 48: Not Supported (0x00)
…0. - MCS Index 49: Not Supported (0x00)
…0.. - MCS Index 50: Not Supported (0x00)
…0… - MCS Index 51: Not Supported (0x00)
…0… - MCS Index 52: Not Supported (0x00)
..0… - MCS Index 53: Not Supported (0x00)
.0… - MCS Index 54: Not Supported (0x00)
0… - MCS Index 55: Not Supported (0x00)
…0 - MCS Index 56: Not Supported (0x00)
…0. - MCS Index 57: Not Supported (0x00)
…0.. - MCS Index 58: Not Supported (0x00)
…0… - MCS Index 59: Not Supported (0x00)
…0… - MCS Index 60: Not Supported (0x00)
..0… - MCS Index 61: Not Supported (0x00)
.0… - MCS Index 62: Not Supported (0x00)
0… - MCS Index 63: Not Supported (0x00)
…0 - MCS Index 64: Not Supported (0x00)
…0. - MCS Index 65: Not Supported (0x00)
…0.. - MCS Index 66: Not Supported (0x00)
…0… - MCS Index 67: Not Supported (0x00)
…0… - MCS Index 68: Not Supported (0x00)
..0… - MCS Index 69: Not Supported (0x00)
.0… - MCS Index 70: Not Supported (0x00)
0… - MCS Index 71: Not Supported (0x00)
…0 - MCS Index 72: Not Supported (0x00)
…0. - MCS Index 73: Not Supported (0x00)
…0.. - MCS Index 74: Not Supported (0x00)
…0… - MCS Index 75: Not Supported (0x00)
…0… - MCS Index 76: Not Supported (0x00)
xxx… - Reserved
…00 00000000 - Rx Highest Supported Data Rate: Not Specified (0x0000)
xxxxxx.. … - Reserved
… …0 - Tx MCS Set Defined: Not Defined (0x00)
… …0. - Tx Rx MCS Set Not Equal: Not Supported (0x00)
… …00.. - Tx Maximum Number Spatial Streams Supported: Not Supported (0x00)
… …0… - Tx Unequal Modulation Supported: Not Supported (0x00)
xxxxxxxx xxx… - Reserved
xxxxxxxx xxxxxxxx - Reserved
HT Extended Capabilities Info: 00000000 00000000 (0x0000)
… …0 - PCO: Not Supported
… …xx. - Reserved
… xxxxx… - Reserved
…00 … - MCS Feedback: No Feedback (STA does not provide MCS feedback) (0x00)
…0.. … - HT Control Field Support: Not Supported
…0… … - Reverse Direction Responder: Not Supported
.xxx… … - Reserved
Transmit Beamforming Capabilities: 00000000 00000000 00000000 00000000 (0x00000000)
… … … …0 - Implicit Transmit Beamforming Receiving Capable: Not Supported
… … … …0. - Receive Staggered Sounding Capable: Not Supported
… … … …0.. - Transmit Staggered Sounding Capable: Not Supported
… … … …0… - Receive NDP Capable: Not Supported
… … … …0… - Transmit NDP Capable: Not Supported
… … … ..0… - Implicit Transmit Beamforming Capable: Not Supported
… … … 00… - Calibration: Not Supported (0x00)
… … …0 … - Explicit CSI Transmit Beamforming Capable: Not Supported
… … …0. … - Explicit Noncompressed Steering Capable: Not Supported
… … …0.. … - Explicit Compressed Steering Capable: Not Supported
… … …00… … - Explicit Transmit Beamforming CSI Feedback: Not Supported (0x00)
… … .00… … - Explicit Noncompressed Beamforming Feedback Capable: Not Supported (0x00)
… …0 0… … - Explicit Compressed Beamforming Feedback Capable: Not Supported (0x00)
… …00. … … - Minimal Grouping: STA supports groups of 1 (no grouping) (0x00)
… …00… … … - CSI Number of Beamformer Antennas Supported: Single Tx antenna sounding (0x00)
… .00… … … - Noncompressed Steering Number of Beamformer Antennas Supported: Single Tx antenna sounding (0x00)
…0 0… … … - Compressed Steering Number of Beamformer Antennas Supported: Single Tx antenna sounding (0x00)
…00. … … … - CSI Max Number of Rows Beamformer Supported: Single row of CSI (0x00)
…00… … … … - Channel Estimation Capability: 1 space-time stream (0x00)
xxx… … … … - Reserved
Antenna Selection (ASEL) Capabilities: 00000000 (0x00)
…0 - Antenna Selection Capable: Not Supported
…0. - Explicit CSI Feedback Based Transmit ASEL Capable: Not Supported
…0.. - Antenna Indices Feedback Based Transmit ASEL Capable: Not Supported
…0… - Explicit CSI Feedback Capable: Not Supported
…0… - Antenna Indices Feedback Capable: Not Supported
..0… - Receive ASEL Capable: Not Supported
.0… - Transmit Sounding PPDUs Capable: Not Supported
x… - Reserved
Extended Supported Rates: 24, 36, 48, 54 Mbps
Element ID: 50 (Extended Supported Rates)
Length: 4 octets
Speed Rate: 24 Mbps
Speed Rate: 36 Mbps
Speed Rate: 48 Mbps
Speed Rate: 54 Mbps
HT Operation
Element ID: 61 (HT Operation)
Length: 22 octets
Primary Channel: 5 (0x05)
HT Operation Information: 00000111 (0x0007) - subset 1
…11 - Secondary Channel Offset: Secondary channel is below the primary channel (0x03)
…1.. - STA Channel Width: Any channel width
…0… - Reduced Interframe Spacing (RIFS) Mode: RIFS is prohibited
xxxx… - Reserved
HT Operation Information: 00000000 00000000 (0x0000) - subset 2
… …00 - HT Protection: No protection mode (0x00)
… …0.. - Nongreenfield HT STAs Present: All HT STAs that are associated are HT-greenfield capable or all HT peer mesh STAs are HT-greenfield capable
… …x… - Reserved
… …0… - OBSS Non-HT STAs Present: Use of protection for non-HT STAs by OBSSs is determined to be not required
HT Operation Information: 00000000 00000000 (0x0000) - subset 3
… ..xxxxxx - Reserved
… .0… - Dual Beacon: No STBC beacon is transmitted
… 0… - Dual CTS Protection: Dual CTS protection is not required
…0 … - STBC Beacon: Primary beacon
…0. … - L-SIG TXOP Protection Full Support: One or more HT STA in the BSS do not support L-SIG TXOP protection
…0.. … - PCO Active: PCO is not active in the BSS
…0… … - PCO Phase: Indicates switch to or continue 20 MHz phase
xxxx… … - Reserved
Basic MCS Set
MCS Bitmask
…0 - MCS Index 0: Not Supported (0x00)
…0. - MCS Index 1: Not Supported (0x00)
…0.. - MCS Index 2: Not Supported (0x00)
…0… - MCS Index 3: Not Supported (0x00)
…0… - MCS Index 4: Not Supported (0x00)
..0… - MCS Index 5: Not Supported (0x00)
.0… - MCS Index 6: Not Supported (0x00)
0… - MCS Index 7: Not Supported (0x00)
…0 - MCS Index 8: Not Supported (0x00)
…0. - MCS Index 9: Not Supported (0x00)
…0.. - MCS Index 10: Not Supported (0x00)
…0… - MCS Index 11: Not Supported (0x00)
…0… - MCS Index 12: Not Supported (0x00)
..0… - MCS Index 13: Not Supported (0x00)
.0… - MCS Index 14: Not Supported (0x00)
0… - MCS Index 15: Not Supported (0x00)
xxx… - Reserved
Vendor Specific: Routerboard: 0
Element ID: 221 (Vendor Specific)
Length: 42 octets
Vendor OUI: 00-0C-42 (Routerboard.com)
Vendor Type: 0 (Unknown)
Data: 00 00 01 1E 00 10 00 00 01 66 21 06 00 00 4B 4A 4A 5F 41 50 5F 42 31 5F 50 00 00 00 00 00 00 00 00 00 05 02 80 09
Text: …f!..KJJ_AP_B1_P…
Vendor Specific: Microsoft: WMM/WME: Parameter Element
Length: 24 octets
Vendor OUI: 00-50-F2 (MICROSOFT CORP.)
Vendor Type: 2 (WMM/WME)
OUI Subtype: 1 (Parameter Element)
Version: 1 (0x01)
QoS Info: 10000000 (0x80)
…0000 - Parameter Set Count: 0 (0x00)
.xxx… - Reserved (0x00)
1… - U-APSD: Enabled (0x01)
Reserved: 0x00
AC Parameters: Best Effort (AC_BE)
ACI/AIFSN: 00000011 (0x03)
…011 - Arbitration Inter Frame Spacing Number (AIFSN): 3
…0… - Admission Control Mandatory (ACM): No
.00… - Access Category Index (ACI): Best Effort (AC_BE) (0x00)
x… - Reserved
ECWmin/ECWmax: 10100100 (0xA4)
…0100 - ECWmin: 4
1010… - ECWmax: 10
TXOP Limit: 0
AC Parameters: Background (AC_BK)
ACI/AIFSN: 00100111 (0x27)
…111 - Arbitration Inter Frame Spacing Number (AIFSN): 7
.01… - Access Category Index (ACI): Background (AC_BK) (0x01)
x… - Reserved
…0100 - ECWmin: 4
1010… - ECWmax: 10
TXOP Limit: 0
AC Parameters: Video (AC_VI)
ACI/AIFSN: 01000010 (0x42)
…010 - Arbitration Inter Frame Spacing Number (AIFSN): 2
.10… - Access Category Index (ACI): Video (AC_VI) (0x02)
x… - Reserved
ECWmin/ECWmax: 01000011 (0x43)
…0011 - ECWmin: 3
0100… - ECWmax: 4
TXOP Limit: 94
AC Parameters: Voice (AC_VO)
ACI/AIFSN: 01100010 (0x62)
.11… - Access Category Index (ACI): Voice (AC_VO) (0x03)
x… - Reserved
ECWmin/ECWmax: 00110010 (0x32)
…0010 - ECWmin: 2
0011… - ECWmax: 3
TXOP Limit: 47
Vendor Specific: Broadcom: HT Capabilities Info (Pre-N HT Capabilities)
Length: 30 octets
Vendor OUI: 00-90-4C (Epigram, Inc.)
Vendor Type: 51 (HT Capabilities Info (Pre-N HT Capabilities))
..x… … - Reserved
xxx… - Reserved
Supported MCS Set
Rx MCS Bitmask
xxx… - Reserved
… …xx. - Reserved
… xxxxx… - Reserved
.xxx… … - Reserved
x… - Reserved
Vendor Specific: Broadcom: HT Additional Capabilities (Pre-N HT Operation)
Length: 26 octets
Vendor Type: 52 (HT Additional Capabilities (Pre-N HT Operation))
Control Channel: 5 (0x05)
Additional HT Information: 00000111 (0x0007) - subset 1
…11 - Extension Channel Offset: Secondary channel is below the primary channel (0x03)
…1.. - Recommended transmission Width Set: Any channel width
…0… - Controlled access only: not only PSMP
000… - Service Interval Granularity: 5 ms
Additional HT Information: 00000000 00000000 (0x0000) - subset 2
… …00 - Operating Mode: Pure HT, no protection (0x00)
… …0.. - Non-GF Devices Present: All HT devices that are associated are GF capable
.xxxxxxx xxxxx… - Reserved
Additional HT Information: 00000000 00000000 (0x0000) - subset 3
… ..000000 - Basic STBC MCS: 0x00
… 0… - Dual CTS Protection: Regular use of RTS/CTS
…0 … - Secondary Beacon: Primary Beacon
xxxx… … - Reserved
Basic MCS Set
MCS Bitmask
xxx… - Reserved
270Mbps operation:
Information Elements: 13 (237 bytes)
SSID: KJJ
Length: 3 octets
SSID: KJJ
Supported Rates: 1, 2, 5.5, 11, 6 (B), 9, 12, 18 Mbps
Length: 8 octets
Speed Rate: 1 Mbps
Speed Rate: 2 Mbps
Speed Rate: 11 Mbps
Basic Speed Rate: 6 Mbps
Speed Rate: 9 Mbps
Speed Rate: 12 Mbps
Speed Rate: 18 Mbps
Length: 1 octet
Current channel: 5
Length: 4 octets
DTIM Count: 0
DTIM Period: 1
Bitmap Control: 00000001 (0x01)
…1 - Traffic Indicator: Group Frames Buffered at AP (0x01)
0000000. - Bitmap Offset: 1 (0x01)
ERP Information
Length: 1 octet
xxxxx… - Reserved
HT Capabilities
Length: 26 octets
HT Capabilities Info: 00010000 00001110 (0x100E)
… ..0… - Short GI for 20 MHz: Not Supported
… .0… - Short GI for 40 MHz: Not Supported
..x… … - Reserved
xxx… - Reserved
Supported MCS Set
Rx MCS Bitmask
xxx… - Reserved
… …xx. - Reserved
… xxxxx… - Reserved
.xxx… … - Reserved
x… - Reserved
RSN Information
Element ID: 48 (RSN Information)
Length: 20 octets
Version: 1
Group Data Cipher Suite: 00-0F-AC (IEEE 802.11), CCMP (4)
Group Data Cipher Suite OUI: 00-0F-AC (IEEE 802.11)
Group Data Cipher Suite Type: CCMP (4)
Pairwise Cipher Suite Count: 1
Pairwise Cipher Suite List
Pairwise Cipher Suite: 00-0F-AC (IEEE 802.11), CCMP (4)
Pairwise Cipher Suite OUI: 00-0F-AC (IEEE 802.11)
Pairwise Cipher Suite Type: CCMP (4)
Auth Key Management (AKM) Suite Count: 1
Authenticated Key Management (AKM) Suite List
Authenticated Key Management (AKM) Suite: 00-0F-AC (IEEE 802.11), WPA-EAP (1)
Authenticated Key Management (AKM) Suite OUI: 00-0F-AC (IEEE 802.11)
Authenticated Key Management (AKM) Suite Type: WPA-EAP (1)
RSN Capabilities: Not Present
Length: 4 octets
Speed Rate: 24 Mbps
Speed Rate: 36 Mbps
Speed Rate: 48 Mbps
Speed Rate: 54 Mbps
HT Operation
Length: 22 octets
xxxx… - Reserved
… …x… - Reserved
xxxx… … - Reserved
Basic MCS Set
MCS Bitmask
xxx… - Reserved
Length: 42 octets
Data: 00 00 01 1E 00 00 00 00 02 66 21 06 00 00 34 43 35 45 30 43 37 43 41 41 41 33 00 00 00 00 00 00 00 00 05 02 80 09
Text: …f!..4C5E0C7CAAA3…
Length: 24 octets
Version: 1 (0x01)
Reserved: 0x00
x… - Reserved
…0100 - ECWmin: 4
1010… - ECWmax: 10
TXOP Limit: 0
x… - Reserved
…0100 - ECWmin: 4
1010… - ECWmax: 10
TXOP Limit: 0
x… - Reserved
…0011 - ECWmin: 3
0100… - ECWmax: 4
TXOP Limit: 94
x… - Reserved
…0010 - ECWmin: 2
0011… - ECWmax: 3
TXOP Limit: 47
Length: 30 octets
..x… … - Reserved
xxx… - Reserved
Supported MCS Set
Rx MCS Bitmask
xxx… - Reserved
… …xx. - Reserved
… xxxxx… - Reserved
.xxx… … - Reserved
x… - Reserved
Length: 26 octets
xxxx… … - Reserved
Basic MCS Set
MCS Bitmask
xxx… - Reserved
Anyway - am I right if I think, the best way to achieve only G/N compatibility is the 802.11Nonly mode? I don’t have any B devices anymore (don’t take included infos into account - it was just set to b/g/n mode).
Second - does the TX power alogorithm on RB951 take internal antenna gain into account? eq. if it subtracting antenna gain by default or do I have to set it in advanced mode? It seems to be a difference there - between what is produced in standalone AP bridge mode (regulatory domain, tx power default) and CAPsMAN mode (regulatory domain, no power settings).
Could not find any TPC report capability in router basebox2 -rel-6.34.3
I could find Tx power limit as per regulatory domain or can keep default.
what about TPC report capability?
Regards,
Abhishek
