Hi,just i want to ask you about my problem. I’ve got RB951 with v6.32.2. So my problem is i couldn’t see the usb on RB951. The thing is i can configure as a FTP server,but i cant use for SMS.
Thanks a lot
What USB device are you trying? More info is needed.
The thing is, when i put external hdd is good RB951 can reading that, but when i put phone to use as a SMS like that picture.. i have a problem
Probably not a supported type, then?
There is a list of supported hardware: http://wiki.mikrotik.com/wiki/Supported_Hardware
no, it was good, i have used before e.g. for sending SMS. One week ago i sow that problem.
Maybe power is not enough for hdd. Why dont u try with a flashdrive?
i have tried with flash disk, it’s good..working very well.The problem is i can’t see usb is system port/ PPP client/ and system sms.
Some devices can operate in multiple modes. You may have mistakenly switched the mode.
See what happens when you connect it to a computer…
im connecting wireless to my computer, it’s working good. also i have changed the version and i tried by netinstal,same thing
. I will take care about your last.
