I’am struggling into something that I think is simple. Basically, I would like my RB951 to work like a simple commercial wifi access point, where you just plug in the cable from the switch on the RB951 LAN port and it will take a management IP and will be giving IP to the client from the switch dhcp range.
What happening is when I connect the RB951 from the switch it gives 192.168.88.* range. Please help.
For that purpose you need to reconfigure your AP. Create transparent bridge with Ethernet and Wireless interfaces in it. In Quick set it’s WISP AP option.
Thank you for your reply, I am a complete beginner with this router, can you please guide me on how to create transparent bridge with ethernet and wireless interface.
