RB951G-2HnD 6.2 final release bugs
Hi, I have found the next issues with the 6.2 final release:
  1. If with ip lan/an 192.168.47.1/24 I add in ip address in “address list” with the ip 192.168.1.2, network 192.168.1.0 for any interface (i use PPPoE but fail with all) then if I press in Quick set the button “apply”, then the ip 192.168.1.1 disappears. This occurs with versions 6.2, 6.1 and 5.25.
  2. This sentence in script language fails when previosIP is blank so the dns not update:
:if ($currentIP != $previousIP) do={
:log info “No-IP: Current IP $currentIP is not equal to previous IP, update needed”
:set previousIP $currentIP
I have used the method of this link: http://wiki.mikrotik.com/wiki/Dynamic_D … _No-IP_DNS and this script was working with 5.25 and 6.1 versions.
With the version 6.1 this script works good.
  1. The type os switch is “unknown” as already explained in other posts.
I had to downgrade to 6.1 for the problem with no-ip.
Regards
I am running quickset on a rb411ar routerboard with RouterOS 6.2. As soon as quickset is launched, Winbox exits.
Is this a bug?
Regards,
Don James
I have that too… except mine doesn’t exit, it just hangs. Either way I’m certainly hoping is a bug and not a feature.
Same here, 951G, 411UAHR
We will fix it in the next RouterOS release.
