RB951G-2HnD and server on the lan - port forward not working
Hey everybody. I just bought new router and I have problems setting it up. I firstly upgraded system to 6.21.1 and then resetted its configuration.
Then I set up PPOE, changed internal LAN IP to different class (10.0.0.0) and fixed DHCP and DNS. This works now flawlessly.
But now I have major issue because port forwading doesn’t work. I tried to add rule through terminal and rule through Winbox. No matter what I do, I can’t reach my server from the internet. If I try to open my web server I get the login screen from router. I can see package counter in “/ip firewall nat” is not changing so I guess router itself ignores this rules.
I tried to forward ports 80, 443, 586 and 143. I’ve tried as it’s described in the wiki (http://wiki.mikrotik.com/wiki/Manual:Initial_Configuration#Static_configuration)
I think u need this
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Grt
