RB951G-2HnD - boot loop after upgrade
Hello everyone,
I’ve ended up with mikrotik rebooting every 10 seconds. Out-of-warranty but working fine until the upgrade.
exactly like in this video:
https://www.youtube.com/watch?v=cjcXbBf91OA
It’s unresponsive to both of reset buttons and it does not show up in netinstall anymore.
What can I do?
Thank you!
Some failure during upgrade. If you back up the settings in your RB you can try the netinstall recovery procedure as described in
https://www.youtube.com/watch?v=V4-dOh9MW-s
Thanks, but how can the video you posted help me? As I said in my original post: “it does not show up in netinstall anymore”
I have the same problem with RBwAP2nD. It work in CAPsMAN mode with RB2011iL-RM. After each! upgrade(in manual or automatic mode via CAPsMAN or package upgrade) RBwAP2nD don’t work. Every time I need to use Netinstall software to reinstall it. I already tried to change RBwAP2nD to another RBwAP2nD. With new one I have the same problem.
