I was setting up RB951G-2HnD as a AP as a test and made a mistake and couldn’t connect to it, no issue i’ll factory reset it, Issue
So once I disconnected the power placed a pin into the reset button and powered on the device and waited till it was blinking
then released the reset button. now it powers on but I cant connect to it at all, plug in a ethernet to any ports and im unable to connect
i’ve now tried resetting a couple of times and same thing
the wireless led is off. when i connect to ethernet the led does come on but unable to identify network (tired with win11 and ubuntu)
tried resetting via the connections on the bottom and same thing
on the first beep it makes a somewhat a chirping sound leading into the beep, and when the 2nd beep happens the wireless led flashes on then goes off
any information would help
Using Netinstall and the link
https://wiki.mikrotik.com/wiki/Manual:Netinstall
connecting to eth01(poe) and disabling windows firewall was able to reset the OS
