i have an interesting problem.I try to recovery evrything so i use reset button then something happend.
The reset button is soo weak then i press i broked the button.
It’s much harder to reset my router without the button.
I check i see there is a jump hole i can use.I try to use but nothing happend ? I don’t know what is the problem i use screwdriver then the router boot normaly.
It this any possibility to save this router or i need to buy new one ?
Thx,
Zsolt
