We’ve bought Mikrotik RB951G-2HnD in our company (about 20 - 25 clients in network) with 50 Mbps channel from the ISP-side.
Mikrotik Wireless drops connection from time to time as often as more people are connected via Wi-Fi:
The current configuration is following:
What point should we start to diagnose and solve this problem?
I’m having the same issues. My connection from my ISP isn’t nearly as high though. As my Wi-Fi gets over 25 users, other machines start disconnecting. I am also using a RB951G-2HnD with RouterOS 6.33.2.
Make sure your DHCP pool isn’t being exhausted - are these always the same clients? Otherwise, you could have leases out to clients no longer connected. If this is the case, decrease the lease time, or use a script to remove the lease upon disassociation from the wireless side.
Use channel width only 20mhz and not 20/40.
try with wmm disable. The setting appear when u press advance button.
Security use only wpa2 aes and not tkip.
Which package you use? Wireless-cm2 or wireless-fp?
