RB951G-2HnD + GM-2420
can RB951G-2HnD work with GM-2420 24V Power Adapter or GM-2440 Power Adapter pluged in directly into RB951 power jack (not over PoE). It came with 12V/1A power adapter but in specs its stated: “Supported input voltage 9-30V” and “Can be powered by Passive PoE: 8-30V” ?
how many A does GM-2420 have ?
is it over 0.8A ? Then it should be fine.
If it’s this, than is more than enough
http://www.telebit.hr/Mikrotik-GM-2440-Power-Adapter-24V-4A/p/92904523.aspx
GM-2420 is 2A, GM-2440 is 4A, yes its more than enough, I was only worried if it will work with 24V since it originally came with 12V power adapter. Don’t want to fry my router :slight_smile:
