Hey guys, I’ve got a RB951G-2HnD that is having some issues. I bought this device earlier this year and it has worked perfectly until now. When I plug an ethernet cable into any of the ports, I am unable to see the router in winbox. Netinstall doesn’t see the router either. I’ve tried different cables and computers. The port flashes when a cable is plugged in to that specific port. I’ve tried resetting it, but according to the manual, the lights should flash at some point after holding the reset button down and booting the router up, but nothing happens. Any ideas? I’m completely stumped, and I’d rather not replace a $70 router.
Have you disabled the firewall on your pc or laptop.
Use ether2-5 for connect to router.
For netinstall use ether1
For the correct procedure see this
http://www.wirelessinfo.be/index.php/mikrotik/pages/netinstalle
