rb951G-2HnD PoE
Hi, is it possible to power on the rb951G-2HnD with PoE on Lan 1 ?
Can I use a PoE Switch or i need a iniector like this http://routerboard.com/RBGPOE ?
Marco
You need poe injector - as link above. Or poe switch http://routerboard.com/RB260GSP
Thank’s for the answer.
If I use the power supply included I can only have PoE output power on LAN 5 to power on another PoE device, is it correct ?
rb951 dont have POE output on port5. Rb951G have only poe Input on port1.
POE output on port5 have http://routerboard.com/RB951Ui-2HnD
RB951Ui-2HnD PoE output function for port #5
http://wifimag.ro/pdf/RB951Ui-2HnD.pdf
Does RB951Ui-2HnD has input power in ether1 & output power in ether 5???
Yes
Hi, wich is the part naumber and where can I buy this POE Adapter for RB951G in Spair or web page international?
Regards
