RB951G-2HnD relatively low speeds on lan/wlan
Just got a new RB951G-2HnD. After unboxing and connecting I’ve made a firmware update to 3.10 and RouterOS to 6.7.
After that the only changes I’ve made to the default configuration is a new password for wlan/admin account, UPnP on and one VNC port forward for one machine.
When this was done I’ve proceeded with some speed testing. What I’ve found out is that I can only get around 70mbps out of my 250mbps bandwidth when connected by cable. Without router it goes up to a full 250mbps without problems. This was tested simply by downloading a few torrents with a lot of seeders. When tried speedtest.net it was even worse than that.
Wireless does no better then that and shows Link Speed of only 72mbps on both my android device (Xperia Z1) and a laptop with real speed at around 20-30mbps (20/40Mhz HT Above enabled). Both devices support 802.11n fully.
I’m completely new to RouterOS and any advice is appreciated.
Post /export so we can see what your router is doing.
There ya go:
jan/13/2014 19:52:57 by RouterOS 6.7
software id = GD8K-572A
add admin-mac=D4:CA:6D:CC:DE:C5 auto-mac=no l2mtu=1598 name=bridge-local
protocol-mode=rstp
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above
country=latvia disabled=no distance=indoors frequency=2422 l2mtu=2290 mode=
ap-bridge ssid="unlimited internet works" wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=
ether5-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=
dynamic-keys wpa-pre-shared-key=12345 wpa2-pre-shared-key=12345
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1
network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no
interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=
invalid
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment=miner dst-port=5900 protocol=tcp
to-addresses=192.168.88.254 to-ports=5900
add action=masquerade chain=srcnat dst-port=5900 protocol=tcp
/ip upnp
set enabled=yes
/system clock
set time-zone-name=Europe/Riga
/system leds
set 0 interface=wlan1
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=wlan1
Still need help.
Can you check if the link speed to the modem is ‘gigabit’?
This is pretty normal. The telephone probably has 1 antenna / 1 chain. Please disable TKIP encryption, leave only AES on. You might gain some speed.
I don’t know what kind of wireless card and antenna configuration the laptop has. It’s maybe the same cause as the phone.
ether1-gateway says:
Auto Negotiation done
Rate 1Gbps
Full Duplex
TKIP is already disabled, still 72mbps. Isn’t it supposed to be a half of 300mbps with 1 antenna - 150mbps?
