I have a problem resetting my RB951G-2HnD router. Tried turning it on while pressing the “reset” button. Tried turning it on with closed jumper. Unsuccessful, it remains in the old configuration. Cannot access RouterOS brcause of bad configuration. Is there another way to reset it?
hi,
sometimes if i having a problem on resetting the device to its factory default config i use netinstall to reinstall the os.
Using reset button on Mikrotik devices (RB951G is no exception) is not entirely straight forward, exact function of the button depends on when button is pressed and when button is released. The different functions are described in reset button manual.
