RB951G-2HND serious wireless issue (RouterOS 5.26/6.12)
Hi guys, it’s my first post here. Hope I’ll get some help :slight_smile:
I have recently bought RB951G-2HND I use it as WiFi for home, but I can’t get it working for more than few seconds. I do see that my wifi signal on my devices (iPad, iPhone) is full, but I barely can use them. Webpages are not working, other applications are constantly reporting ‘no internet connection’ etc.
Ping from my work laptop (Thinkpad T410) is showing significant packet loss. I almost got that fixed by turning down TX rates on my device, but…
I have upgraded to 6.12 and can’t get that working anymore. I’m getting message:
Couldn’t change Interface - tx-power-mode not supported (6)
Any ideas? I really can’t use any wireless device at home anymore.
Hey,
If you can print a export of the config for the wireless we all can see how it is configured and see what the issue may be
/interface wireless export
we can get a clearer picture,
Cheers
Kev
I would suggest to reset the wireless interface configuration and set the options you only need.
To lower the tx-power on the RB951G you need to use tx-power-mode=all-rates-fixed.
Here you have output from the /interface wireless export command:
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n bridge-mode=disabled channel-width=20/40mhz-ht-above country=
“czech republic” disabled=no distance=indoors l2mtu=2290 mode=ap-bridge ssid=“xxxxxxxx” tx-power-mode=
all-rates-fixed wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys wpa-pre-shared-key=yyyyyyyy
wpa2-pre-shared-key=yyyyyyyy
This is what I have set actually :slight_smile:
i would suggest changing the channel width to 20MHz only as some devices dont like the 20/40 HT Above
try putting this in and changing the country code and channel you wish to use
add authentication-types=wpa2-psk eap-methods="" group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=allowed \
    management-protection-key="" mode=dynamic-keys name=Security radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no \
    radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none \
    static-algo-3=none static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" \
    static-transmit-key=key-0 supplicant-identity="" tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key="" \
    wpa2-pre-shared-key=12345678
/interface wireless
    set 0 adaptive-noise-immunity=ap-and-client-mode allow-sharedkey=no \
    antenna-gain=0 area="" arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps \
    basic-rates-b=1Mbps bridge-mode=enabled channel-width=20mhz \
    compression=no country="united kingdom" \
    default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=\
    0 default-forwarding=yes dfs-mode=no-radar-detect disable-running-check=no disabled=\
    no disconnect-timeout=3s distance=indoors frame-lifetime=0 frequency=2437 \
    frequency-mode=regulatory-domain frequency-offset=0 hide-ssid=no \
    ht-ampdu-priorities="" ht-amsdu-limit=8192 ht-amsdu-threshold=8192 \
    ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
    ht-guard-interval=any ht-rxchains=0,1 ht-supported-mcs="mcs-0,mcs-1,mcs-2,\
    mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-\
    14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" \
    ht-txchains=0,1 hw-fragmentation-threshold=disabled hw-protection-mode=\
    none hw-protection-threshold=0 hw-retries=7 l2mtu=2290 \
    max-station-count=2007 mode=ap-bridge mtu=1500 \
    multicast-helper=default name=wlan1 noise-floor-threshold=default \
    nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key="" \
    nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
    on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=both \
    proprietary-extensions=post-2.9.25 radio-name=WiFi \
    rate-selection=advanced rate-set=default scan-list=default \
    security-profile=Security ssid=WiFi station-bridge-clone-mac=\
    00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power=17 tx-power-mode=\
    card-rates update-stats-interval=disabled wds-cost-range=50-150 \
    wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
    disabled wireless-protocol=802.11 wmm-support=disabled
i put this in some of my clients and not have any issues with wireless :slight_smile:
oh and set the No-Radar Detect to None oops typo in my config
Actually I think I had different issue here. Had - because it seems to be solved now.
I’m using mikrotik purely as wifi + ethernet switch as I do routing/firewalling/etc. on my BSD box. It ended up after some tcpdumping and thinking that my mikrotik device were using same IP address as my gateway (surprise, no idea why) and after my wireles devices autheticated to wifi actual pactekts were routed once through my gateway, another one through mikrotik’s fake gateway which resulted in dropped connections.
Nevertheless - thank you for your prompt reply. So far everything is working here.
