Deal all, good afternoon.
I have this router on os 6.48.6 and i have connect a USB GPS antenna in order to use it for polling location.
I am ok with scripting etc but when activate the antenna, it only works for few seconds and then stop and not all the times. I tried to change baudrate etc settings without success.
Any opinions?
Edit : When changing the baudrate , works for few seconds and stop. If i stop and start doesnt work again. Only after change baudrate.
My setup as below :
# nov/10/2022 16:14:04 by RouterOS 6.48.6
# software id = R9NY-9LNP
# model = RB951G-2HnD
# serial number = DE350F35AA20
add admin-mac=DC:2C:6E:D3:6F:73 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid="MikroTik GPS" wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=gr09gr09gr09
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/port
set 0 baud-rate=4800 name=usb1
/interface ppp-client
add apn=internet name=ppp-out1 port=usb1
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
set time-zone-name=Europe/Athens
/system gps
set coordinate-format=dms enabled=yes port=usb1
/system scheduler
add interval=1h name=gps on-event=gps policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/08/2022 start-time=10:52:00
/system script
add dont-require-permissions=yes name=gps owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=":\
local email \"giannis.karantanis.82@gmail.com\";\r\
\n\r\
\n:system gps monitor file=\"gps.txt\";\r\
\n:global gpstext [/file get gps.txt contents];\r\
\n:local longstart [:find \$gpstext \"longitude\" -1];\r\
\n:local longend [:find \$gpstext \"\\n\" \$longstart];\r\
\n:local latstart [:find \$gpstext \"latitude\" -1];\r\
\n:local latend [:find \$gpstext \"\\n\" \$latstart];\r\
\n:local validstart [:find \$gpstext \"valid\" -1];\r\
\n:local validend [:find \$gpstext \"\\n\" \$validstart];\r\
\n:local valid false;\r\
\n:local zeros \"\";\r\
\n\r\
\n:if ([:find \$gpstext \"yes\" \$validstart] > 0) do={:set valid true;};\
\r\
\n\r\
\n:global longitude [:pick \$gpstext (\$longstart + 11) \$longend];\r\
\n:local degreestart [:find \$longitude \" \" -1];\r\
\n:local minutestart [:find \$longitude \" \" \$degreestart];\r\
\n:local secondstart [:find \$longitude \"'\" \$minutestart];\r\
\n\r\
\n:local secondend;\r\
\n:local secfract;\r\
\n\r\
\n:if ([:len [:find \$longitude \".\" 0]] < 1) do={\r\
\n :set secondend [:find \$longitude \"'\" \$secondstart];\r\
\n :set secfract \"0\";\r\
\n} else={\r\
\n :set secondend [:find \$longitude \".\" \$secondstart];\r\
\n :set secfract [:pick \$longitude (\$secondend + 1) (\$secondend + 2)\
];\r\
\n};\r\
\n\r\
\n:local longdegree;\r\
\n:local longdegreelink;\r\
\n\r\
\n:if ([:pick \$longitude 0 1] = \"W\") do={\r\
\n :set longdegree \"-\";\r\
\n :set longdegreelink \"W\";\r\
\n} else={\r\
\n :set longdegree \"+\";\r\
\n :set longdegreelink \"E\";\r\
\n};\r\
\n\r\
\n:set longdegree (\$longdegree . [:pick \$longitude 2 \$minutestart]);\r\
\n:set longdegreelink (\$longdegreelink . [:pick \$longitude 2 \$minutesta\
rt]);\r\
\n:local longmin [:pick \$longitude (\$minutestart + 1) \$secondstart];\r\
\n:local longsec [:pick \$longitude (\$secondstart + 2) \$secondend];\r\
\n:local longfract ((([:tonum \$longmin] * 6000) + ([:tonum \$longsec] * 1\
00) + ([:tonum \$secfract] * 10) ) / 36);\r\
\n\r\
\n:while (([:len \$zeros] + [:len \$longfract]) < 4) do={\r\
\n :set zeros (\$zeros . \"0\");\r\
\n};\r\
\n\r\
\n:global newlong (\$longdegree . \".\" . \$zeros . \$longfract);\r\
\n:global newlonglink (\$longdegreelink . \".\" . \$zeros . \$longfract);\
\r\
\n\r\
\n:global latitude [:pick \$gpstext (latstart + 10) \$latend];\r\
\n:set degreestart [:find \$latitude \" \" -1];\r\
\n:set minutestart [:find \$latitude \" \" \$degreestart];\r\
\n:set secondstart [:find \$latitude \"'\" \$minutestart];\r\
\n\r\
\n:if ([:len [:find \$latitude \".\" 0]] < 1) do={\r\
\n :set secondend [:find \$latitude \"'\" \$secondstart];\r\
\n} else={\r\
\n :set secondend [:find \$latitude \".\" \$secondstart];\r\
\n :set secfract [:pick \$latitude (\$secondend + 1) (\$secondend +2)];\
\r\
\n};\r\
\n\r\
\n:local latdegree;\r\
\n:local latdegreelink;\r\
\n\r\
\n:if ([:pick \$latitude 0 1] = \"N\") do={\r\
\n :set latdegree \"+\";\r\
\n :set latdegreelink \"N\";\r\
\n} else={\r\
\n :set latdegree \"-\";\r\
\n :set latdegreelink \"S\";\r\
\n};\r\
\n\r\
\n:set latdegree (\$latdegree . [:pick \$latitude 2 \$minutestart]);\r\
\n:set latdegreelink (\$latdegreelink . [:pick \$latitude 2 \$minutestart]\
);\r\
\n:local latmin [:pick \$latitude (\$minutestart + 1) \$secondstart];\r\
\n:local latsec [:pick \$latitude (\$secondstart + 2) \$secondend];\r\
\n:local latfract ((([:tonum \$latmin] * 6000) + ([:tonum \$latsec] * 100)\
\_+([:tonum \$secfract] * 10)) / 36);\r\
\n\r\
\n:set zeros \"\";\r\
\n\r\
\n:while (([:len \$zeros] + [:len \$latfract]) < 4) do={\r\
\n};\r\
\n\r\
\n:global newlat (\$latdegree . \".\" . \$zeros . \$latfract);\r\
\n:global newlatlink (\$latdegreelink . \".\" . \$zeros . \$latfract);\r\
\n\r\
\n:global coordinates (\$newlong . \",\" . \$newlat);\r\
\n\r\
\n:global linkout \"http://maps.google.com\?q=\$newlatlink+\$newlonglink\"\
;\r\
\n\r\
\n:global kmlout \"<\?xml version=\\\"1.0\\\" encoding=\\\"UTF-8\\\"\?>\r\
\n<kml xmlns=\\\"http://www.opengis.net/kml/2.2\\\">\r\
\n <Placemark>\r\
\n <name>M/V GR09</name>\r\
\n <description>M/V GR09 location</description>\r\
\n <Point>\r\
\n <coordinates>\$coordinates</coordinates>\r\
\n </Point>\r\
\n </Placemark>\r\
\n</kml>\r\
\n\";\r\
\n\r\
\n:if (valid) do={\r\
\n :global oldpos;\r\
\n\r\
\n :if (\$oldpos != \$coordinates) do={\r\
\n /file set [/file find name=gps.kml] contents=\$kmlout\r\
\n /tool e-mail\r\
\n send to=\$email subject=\"Vessel moved\" body=\"Moved to \$latit\
ude \$longitude\\r\\n\$linkout\\r\\n\$SMlinkout\" file=gps.kml\r\
\n :set oldpos \$coordinates;\r\
\n };\r\
\n} else={\r\
\n /tool e-mail\r\
\n send to=\$email subject=\"Router gps position invalid\" body=\"\
Router gps position invalid\"\r\
\n};\r\
\n\r\
\n"
/tool e-mail
set address=64.233.166.108 from=example@gmail.com password=\
xxxxxxxxxxxxxxxxxx port=587 start-tls=yes user=\
example@gmail.com
/tool mac-server
/tool mac-server mac-winbox
