Hello guys,
Some question that popped into my mind after reading articles here and there regarding the bridge and switch function on the Mikrotik routers.
I did’t touched the default config with regards the bridged ports configured - thats also the situation with the switch ports.
/interface bridge port> print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether2-master-local bridge-local 0x80 10 none
1 wlan1 bridge-local 0x80 10 none
/interface ethernet switch port> print
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER
0 ether1-gateway switch1 disabled leave-as-is
1 ether2-master-local switch1 disabled leave-as-is
2 ether3-slave-local switch1 disabled leave-as-is
3 ether4-slave-local switch1 disabled leave-as-is
4 ether5-slave-local switch1 disabled leave-as-is
5 switch1_cpu switch1 disabled leave-as-is
I don’t need VLANs..I just want to know is it possible to bring down the CPU usage on the router if i remove (disable) the bridge and configure routing for the clients accessing the network from the Wireless interface instead?
On most of the places i’ve seen that bridging is function realized in software and takes CPU time to execute, while switching is incorporated in hardware…There is no way to allow wireless users connect to the network without bridge or routing because the wireless chip does not have direct connection to the switch..
So i’m thinking will there it be a CPU cycles saving if i configure routing instead of bridging for the wireless interface clients connecting?
