RB951G-2hnd using AR9344 or AR9344N SoC
I’d like someone(preferably from MikroTik) to confirm which SoC is used for RB951G-2HND, AR9344 or AR9344N?
I’d like to know if the chip supports hardware NAT .
Thank-you
Ros does not support hnat. You wouldn’t use it anyway until you get rid of ros and install some other operating system that might be supporting it.
Thank-you for the response but I’d like to know the pure hardware spec please regardless of which OS is running on it.
