RB951G-2HnD vs RB750UP
Hi All,
We are evaluating the Mikrotik devices for remote VPN branch routers. I am comparing the RB951G-2HnD vs RB750UP. Both cost same. Yet everything points to the RB951G-2HnD as better device i.e better CPU/RAM and wireless etc.
Why is the RB750UP relevant here? if that more rugged? Is it better due to any reason?
When is it likely to be phased out?
In short what is good to work in a remote store environment? the 750 or 951?
Thanks / DP
750 is an older model. The RB951G-2HnD is an upgrade of it. I think you don’t need to think about it at all, both will do the job and they will receive the same software updates, but you get better hardware and bonus wireless on the 951.
rb750UP have poe OUTPUT on 4ports. rb951G dont have this feature
http://wiki.mikrotik.com/wiki/Manual:PoE-Out
