rb951G only supports up to 50MB
It is my understanding the rb951G (g series) it only supports up to 50 MB only?
How true is this?
50MB where?
Wired is gigabit (1000mbps) and Wireless, max is 300mbps on N with channel width 40Mhz.
Yes it’s true.
After 50MB the router will shut down. You need to wake it up with rooster.
… and don’t forget to change wall plug everytime otherwise it won’t start as it remembers the last five used wall plugs…
With ~1500 byte packets and utilizing fastpath/fasttrack, you can probably route about 850mbps (~90MBps) single stream tcp.
Anything more than simple routing (IPSec, VPN, etc) will bring it down quite a bit.
