RB951G seems to be brick
I have a RB951G-2HnD (SN 642F05CF5E6B/540) that is behaving weirdly. There problem is that I can´t access the box through the IP 192.168.88.1, even when I reset it through the reset button near to the power jack. I got not beep, no symptom of life from the RouterOS.
To check if it is somehow breathing, I did a capture with wireshark during the startup of the router, from the power on, but I see none frame or packet coming from the router (no ARP, spanning tree, or any kind connection atempt from the router).
However, when I use this router as a bridge, it works ok. I´ve plugged one of its port to my Internet Gateway, and another port of the RB951 to my PC, and my PC accessed the internet with no problem, and the performance Ok.
I´ve tried to reinstall it with Netinstall, but no lucky as expected, once the RB951´s IP is not responding.
Some clue on how to recover my router?
