RB951U No WiFi signal and ETH LED Ports
Hello guys,
I am using RB951U-2HND as a Hotspot retailer for about two years until the router stops giving wireless signal, led ports for eth are not blinking and cannot connect to it thru browser.
Tried to do hard reset but still eth and wifi led are not blinking; tried to do netinstall, it can be detected by my PC but after installing v6.45.5 still no progress.
Is my router dead? I doubt the eth ports are not working if i can see it in netinstall list. But why is’t the led ports are not blinking.
Try another power supply, also wouldn’t hurt to check if there are any bad capacitors and change them.
Sent from my SM-A520W using Tapatalk
