We have 951U as client routers, and using Metal 2SHPn as CPE devices. When enabling the POE on port 5 to either Auto On, or Forced On, The red LED just blinks every 3 seconds or so after a reboot. We’ve tested different cables, and different 951’s and 2SHPs (we have about 15 we are trying to install) and they all do the same thing. Putting a current meter on the cable only indicates about 100-115ma of current during the boot process of the Metal. We’ve seen posts of other having this issue, and suggestions to downgrade to 6.17, however, the problem continues with all older versions we have tried. Powering a Groove 25 works just fine with the same ROS level. Leaving the unit in this mode, (blinking red LED) yields something on the board overheating, as we begin to smell hot components. This has been reproduced on 3 951 units from the same batch. This batch mac addresses end with a /435. We tested on a 951 unit from batch /348 and it experiences the same issue.
Model 951Ui-2HnD
Serial Number 4AC804B960EF
Current Firmware 3.19
Upgrade Firmware 3.19
The Metal batch numbers end in /438 that are problematic. We located an older Metal, with a batch number of /342 which will boot up fine with the newer 951Us. This makes us wonder if the Metals we received have a different chip set, or ethernet chip that is not being sensed by the power circuit in the 951 correctly, or they are just defective.
Model Metal 2SHPn
Serial Number 590004D8DDD0
Current Firmware 3.21
Upgrade Firmware 3.21
If we allow the unit to boot, without the Metal CPE in port 5, and then insert the POE cable, it will sometimes power up. However that is a problem if the units lose power. Having the customer remove/replace the cable is not a good solution. If we remove the cable from port 5 while the red led is blinking, wait, then plug the cable back in the Metal will sometimes power up fine.
It appears that during boot, the auto-on circuit gets confused and begins a teeter-totter of on/off from a power up boot until the cable is removed and replaced.
Is this a hardware problem that we should return the batch of equipment? Or is there a known way to make the POE port support the device on boot. The specs say up to 500ma of current, and we are powering the 951U with a 2.5A power supply and still see the problem.
We tested with a Map2n and it will power the Metals up fine, both via the RouterOS switch, and after a reboot. It is running version 3.17 of the bootloader.
Please advise as to a solution.
Thank You!!
