I cannot find the POE-out setting on RB951Ui-2HnD.
I just setup RB951Ui-2HnD. POE-out on ether5 works well, but where do one power off / on as on RB750UP? Or does it only use the auto on function?
Ok I found that it can only be set via Terminal
Have you running ROS 6.3 ?
No 6.2. Is the option available in 6.3?
Ok thanks
