RB951Ui-2HnD+Huawei E327
Good day.
Huawei E3272 detected as a USB device, but nothing appears under ports.
[admin@MikroTik] > /system resource usb print
DEVICE VENDOR NAME SPEED
0 1:1 Linux 3.3.5 ehci_hcd RB400 EHCI 480 Mbps
1 1:2 Technology Mobile 480 Mbps
[admin@MikroTik] > /port print
Flags: I - inactive
DEVICE NAME CHANNELS USED-BY BAUD-RATE
[admin@MikroTik] >
RouterOS is http://www.mikrotik.com/download/share/routeros-mipsbe-6latest.npk
routerboard: yes
model: 951Ui-2HnD
serial-number: 4AC702EC54B7
current-firmware: 3.16
upgrade-firmware: 3.16
What could be the reason?
Detected on PC:
manufacturer - Huawei modems
model - Auto detect (recommended)
Found Applications port COM6
Found modem : E3272
Model : Huawei E3272
IMEI : 867503015610343
Serial NR. : J5HBYA93B1500253
Firmware : 21.436.05.00.143
Compile date / time : Aug 06 2013 09:04:44
Hardware ver. : CH1E3272SM
Dashboard version : UTPS21.003.28.52.143_MAC21.003.28.49.143_LNX21.003.28.21.143
SIM Lock status : unlocked
Wrong codes entered : 0 (unlock attempts left : 10)
This device is not compatible i think.
http://wiki.mikrotik.com/wiki/Supported_Hardware
Normally there would be an LTE port should appear
I have tested with other 3G modem and set this online, not in Englisch but follow the printscreens a made.
http://www.wirelessinfo.be/index.php/mikrotik/pages/3g
Try the following:
  1. Connect the modem to the router
  2. Shutdown and power off the router completely
  3. Wait few minutes
  4. Power on the router
Received a response from tech support, their engineers to remotely connect and try to adjust:
currently we are unable to add support for this modem.
Maybe you could try to look if it is possible to change the modem to a
different operational mode.
Also I would suggest to look up in the Mikrotik Forum for other user experience
about this modem.
I will use a different series of LTE modems :huawei e3276 - to be working fine
As you know that the mobile phone signal jammer can cut off the signals of the mobile phones and soon make it impossible to make phone calls or send messages. In this way when you need the peaceful condition and want to stay in it, you can just use the best mobile phone jammer to help you achieve your goal. And now as the technology develops with high speed the advanced Cell Phone Blockers has come into the market and are well welcomed by the group of people who need the jammer product.
gps signal jammer can help a lot if you really need it for your car right now.
If you want to own a quiet circumstance for yourself, then you need to come to have a look at the signal jammers for you, there can be so many kinds of to choose, however, the portable one will be suitable for you in my opinion.
