RB951Ui-2HnD POE
I have a RB951Ui-2HnD running 6.2 and created a POE crossover cable. I am trying to power a Canopy SM with it. I have it set to “forced-on” and yet it does not seem to power the Canopy. The red light does slow flash though.
http://wiki.mikrotik.com/wiki/Manual:PoE-Out
The Canopy SM should draw about 350ma which should be acceptable since POE version 1.x can handle 500ma and POE version 2.0 can do 1000ma.
The upgrade command does not seem to be present to tell if I have version 1.x or 2.0 of the POE firmware.
Have you verified that pins 4&5 are - an 8&9 are +24VDC after your power cross over?
Yes, I used a premade POE crossover cable. Check with volt meter. Went ahead and made my own cable as well. Same result.
Hi. Just wanted to find out how do you get to the POE -out setting on this RB951Ui-2HnD? I cant find it and by deafault it seems to be set on auto on?
/interface ethernet set ether5 poe-out=forced-on
Yes I found that, but there’s nothing in winbox
Missing winbox configuration will be resolved in future RouterOS releases.
OK Thanks
