Dear All,
I’ve four of RB951Ui-2HnD running the same Router Board OS 7.9.1 with the same firewall configuration. My problem is, one of those four is using 98.x MiB of 12MiB of storage space while the others only use around 37MiB to 40MiB of 128MiB. I tried to find the way to check the used space or other way to fix the storage issue but seems no luck.
Anyone please share me some tips.
NOTE: those four routers are placing at remote location that I can’t perform netinstall or reset.
Regards,
Sokeada
