RB951Ui-2HnD - Stuck on loop after upgrading to 6.49
Hi Guys,
I have a RB951Ui-2HnD which is stuck in a loop after upgrading to 6.49v. I tried all forms of resettings(power off then reset & wait for the beep) but nothing works. I tried Netinstall over ethernet and some issue, The unit won’t load as the ethernet ports keeps going up/down intermittently.
The unit has a USB slot. Is there a way to console to the unit via USB or some other way?
I’d like to get to the main menu and fix it by consoling, if possible.
Any help is much appreciated.
Thanks.
Pipa.
I always recommend the following when using a device with usb but no console port:
https://mikrotik.com/product/woobm
