RB951Ui-2HnD v6.15 no poe settings available
Hello, i can’t monitor voltage and current in my RB951. When i issue this commands as you told in another post i get this:
 /interface ethernet poe settings print
bad command name settings (line 1 column 25
With
interface ethernet poe monitor ether5
i get only this message:
poe-out-status: powered-on
Poe setting version prints 0.0 in winbox.
Would you be so kind to help me to find the problem? I think more people has the same problem than me.
Thank you very much.
RB951Ui-2HnD like all RB2011i series do not have any monitor or settings on “i” port (except PoE auto on / forced on / off).
This is not the 750UP or OmniTIK UPA-5HnD, the “i” board have only 500mV support @ 24V, just for power one SXT or Sextant.
Ah, thank you very much!
I didn’t know that, i’ve read the wiki but maybe i didn’t see it.
Thanks again!!!
