RB951Ui-2nD RF connectors
Hi people, short of buying a stack of different patch leads, does anyone know what RF connector is on the PCB for the wifi on a RB951Ui-2nD?
I need mount this in a metal box thus need external antennas.
Cheers
Cam
that connectors are not for external antenna, that connector are used for internal testing at the factory
i think you need this
https://routerboard.com/RB912UAG-2HPnD-OUT
Thats a bummer, I might swap it out or just solder a cable straight on permanently.
Thanks chechito
