Good afternoon friends,
I have a dual band RB952Ui, configure your networks, the 5GHz version does not appear, how can I resolve this issue? tried several channels and nothing.
Does your laptop / WiFi card support 802.11ac?
Does your laptop / WiFi card support 5 GHz band?
Try the upper range channel.
Try limiting the bandwidth to only 20/40MHz
Here’s my settings. You can access it from Wireless Tables → double click on wlan2 → Wireless tab.
Hope it helps.
