upgrading the license to extended channel doesn’t work about rb953.
May I have some officeial word about it from MT?
regards
Ros
regards
Ros
On what way you “upgrade” the licence?
using the appropriate task on your private area on MT website.
regards
Ros
Yes, it doesn’t support this feature. The Wireless chip doesn’t support it. Only older products with Merlin chipset support this.
Vedo che non hai capito.
Se hai comprato una licenza di Livello X hai sbagliato, basta mettere “superchannel” in frequency mode, se l’apparecchio supporta quella caratteristica.
