RB953GS-5HnT-RP and 2x2 MIMO
Hi, this is going to strike you as a newbie question, but:
The RB953GS-5HnT-RP supports triple chain, but is it possible to only connect two antennas and operate the built-in 5GHz wireless in 2 chain (2x2 MIMO) mode? If so, does it need to be configured in RouterOS, or is it just a simple matter of only connecting the two antennas?
You have to explicitly enable or disable the chains you want to in configuration. Very easy.
Thanks jarda
Your welcome.
