HI,
after I fried the second usb ethernet adapter I noticed that I was connected to port 5 of the router which is the poe out port. So I measured the pins on the plug and noticed that I can measure 9V between pin 4/5 and 7/8 which are the poe pins.
So I went into the settings and set poe-out to forced-off and rebootet the router
https://wiki.mikrotik.com/wiki/Manual:PoE-Out#Port_Settings
tells me that there should be no sensing and all voltages should be turned off as well, which in fact is not the case I still can measure the 9V, even they change to 11V.
I have two of the above mentioned routers, both are showing this. I supply both via the regular power supply, no poe involved.
How can I turn this off? This seems not standard compliant to me. Any ideas?
