At the moment I have two hAP ac running wifi pretty stable, but band steering gets important to me and this does not work on mikrotik. I want to test two of the Unifi APs (UAP-AC-LR). Those are can be powered via 802.3af/A PoE & 24V PoE.
Now my question is - and this is what I am not sure after what I have read so far - if I can run the UAP-AC-LR without its additional PoE injector together with my mikrotik. Port 5 of my hAP ac is a Passive PoE out port if I read the technical documents correctly. Does Unifi work on this port in Gigabit connection?
I need your help since I do not want to break either of both devices due to incompatibility or voltages issues.
Has anyone some experience on this?
simply answer your question, AC-LR works with HAP AC port 5.
But, the bandwith of this kind of connection is lower compared to attach LR to a gigabyte port switch.(if you don’t have other gigabyte switch connected to HAP AC, then never mind)
Thank for your answers..
I am just diving deeper into those band steeering and roaming issues…And also found a Cisco AP that could be interesting for me. Could that also be connected?
May I ask, would a Cisco AP (e.g. the 1832) be able to connect? In its datasheet they say 802.3af/802.3at or Enhanced PoE. Is Enhanced PoE compatible with the Mikrotiks?
Why are there so many different standards… mhhmmmhm…
I would be really glad to receive some feedback on my additional questions… Have a nice weekend anyways
Thanks a lot, empy
The PoE the hap AC kicks out is 24v so only really Mikrotik and Ubiquiti use it. Even then UBNT are moving to af/at on the UniFi stuff as it’s more “corporate”.
@Steveocee, you did mean Wireless devices under AC-LR to WAN speed, and i was talking about LAN to LAN (wireless device under AC-LR talking to other LAN devices connected to HAP AC)
For example, playback bluray moveis by using KODI app on a iPad (connected to AC-LR, NFS file server is connected to a gigabyte switch) is glitch when i connect AC-LR to HAP AC port 5. While it is smoothless when connect AC-LR to a gigabyte switch LAN . My typing looks like confuse, but it’s the best i can describe, the switch on HAP AC is not gigabyte capable as it claimed.
