So I am having an issue with my rb962uigs 5hact2hnt were off of my Cisco Catalyst 3750G it is not being able to be powered up via port one on mikrotik. Since then I have tested multiple poe switches (dumb and managed) and not one would power it up. Then I started trying power bricks to force the poe voltage to the devices, and only two out for 6 different ones worked (one at 56v and the other at 48v).
Im at a loss for the reasoning behind in, maybe the pinout? Was seeing if anyone else had or is having this same issue.
