RB962UiGS-5HacT2HnT | RouterOS 6.46 | FW: 6.45.1 - Connected, no internet
Hello dear Folk!
I’m really newbie here, fresh Mikrotik owner.
I have the mentioned model which works fine till now, except in Windows 10. My Android-based phone have no issue at all.
Once I configure the Wifi connection (regardless 2,4 or 5 GHz) the connection is established, but no internet (“Connected, no internet”)
Here is the export (as I saw it other topic):
# dec/11/2019 21:49:59 by RouterOS 6.46
# software id = GG8T-GDG8
# model = RB962UiGS-5HacT2HnT
add admin-mac=C4:AD:34:21:E7:2B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=04:8D:38:62:E9:A8
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-b/g/n channel-width=20/40mhz-XX country="czech republic" disabled=no distance=indoors frequency=2432 frequency-mode=regulatory-domain installation=indoor mode=\
    ap-bridge ssid=Pandinvs-24 wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=2 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="czech republic" disabled=no distance=indoors frequency-mode=regulatory-domain installation=indoor mode=ap-bridge \
    ssid=Pandinvs-5 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=******* wpa2-pre-shared-key=******
add name=profile supplicant-identity=MikroTik wpa-pre-shared-key=***** wpa2-pre-shared-key=*****
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Europe/Prague
/system routerboard settings
set cpu-frequency=840MHz
/tool mac-server
/tool mac-server mac-winbox
Thank you in advance!
If your Android phone can connect to same wireless connection with no issues and access internet, you should first check on your PC if you are getting address from DHCP, if you are, then check if you can ping 192.168.88.1, and afterwards try pinging some public IP address, check “route print” on the PC, check if DNS is working.
If DHCP client is enabled on PC and you are not getting any address from the Router, and there is nothing of note in the log, you might want to add additional logging topics for DHCP.
https://wiki.mikrotik.com/wiki/Manual:System/Log#Topics
