RB962UiGS-5HacT2HnT slow LAN speed
So need some light on about this device. Got it week ago, using basically the default configuration just with slight changes on port naming and addressing the rest seems to be good for me. Device itself works good no troubles. All LAN goes in 1Gbps negotiation with other end.
I have service of 360Mbps down and 50 up from my cable broadband ISP. Bur the max i get over LAN is only around 100Mbps sometimes it jumps to 150 or even more but doesn’t hold that and goes back close to 100Mbps.
Wifi the same on AC jumps to 170 and slows down to 100 looks like some kind of limitation or throttling on router board bur cant find why?
Any ideas?
