Hi, i’ve bought 2 RBcAP2n. I don’t know how to turn it on.
I’ve tried connecting them to the Power+Ethernet cable that they come with, but neither of the device turns on. How do you turn them on?
The supplied PoE injector only emits power on its “female” side, and you need to use an additional piece of cable in between your cAP and injector. Make sure you connected them properly.
Ah..! I see ![]()
Thanks, it worked ![]()
