RBcAPGi-5acD2nD
Hi pls someone to help with better settings for RBcAPGi-5acD2nD
If I localy download from me smb server on 5GHz it’s only 120mbit
With asus AP is higher then 370mbit
I past screen of me settings.
Any ideas whitch I can change to faster down/up.
thx for any help.
Don’t use auto, specify channel (i.e.) manually.
Rates: basic 12 Mbps, supported: 12/18/24/36/48/54
Country: select yours
Installation: indoors
Security: use aes only
What firmware version are you using? The latest stable is working very good for me.
Clarify a bit more. How is the test done, what devices involved, how all are connected?
Channel scan and use less used
If I select me country can't use superchannel
fw latest 6.46.4
security only eas
download from smb server on ubuntu which is connect on LAN 1Gbit.
It involve macbook pro and smb server.
On old Asus rt-ac68u can download from server 300mb/s on this AP speed is only 100mb/s
I find best config for transfer via RBcAPGi-5acD2nD
Where is the Linux connected via LAN? Directly to the cAP ac unit? Or there are more devices ?
directly to router via cabel
pls look to pictures of settings , if you will change something to enable wifi faster traffic.
With the same setup, I can get 500Mbit or similar.
Can you just make a new drawing, with a diagram of how it is connected.
