I try something that is working on a RB2011 on a RBD52G-5HacD2HnD and is not working. The two devices run on ROuterOS 6.44.5 LTS
i have a default configuration where i download a config file with :
:tool fetch \$urlGetConf\
here is the test configuration :
while ([:len [/interface find]] < 5) do={}
add comment=factory name=factory-dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=factory-dhcp disabled=no interface=ether5 name=factory
add address=192.168.88.1/24 comment=factory interface=ether5 network=192.168.88.0
add address=192.168.88.0/24 comment=factory
The command i use for changing the configuration to the newly downloaded
:system reset-configuration keep-users=yes skip-backup=yes run-after-reset=(\$serialNumber.\".rsc\)
When the router is up after the reboot nothing is working, in winbox i can see the router but it has no ip address and i can’t log in to.
Anyone as the same problem ? I realy can’t figure out what is going on.
