RBD53iG WiFi and VLAN
Hi there,
currently I have an “RB941-2nD” configure to have 3 VLAN on ethernet1 and 3 WiFi network.
VLAN have these ID: 4, 10, 20.
I bought an “RBD53iG” to have 5 GHz WiFi, and I trying to copy maually the configuration.
I configured the WLAN section, then I added the three VLAN to ether1 and in the end I added the interfaces to the corresponding bridge.
I cannot change the “role” from each interface on the bridge.
On my previous route I had some port marked as “Designated Port” and one “Root” port. I don’t remember how to change the role.
Another question is, this configuration is the best for this router or can I do somethin better?
In attached my configuration.
Thank you very much for the help!
myconfig.cfg.rsc (2.12 KB)
Looks like your attempting to add this as an AP/switch to an existing MT or other router…
https://forum.mikrotik.com/viewtopic.php?t=182276
Yes exactly.
I need to connect the router to an existing infrastructure.
I’m want to understand the best way to handle VLAN:
  • Via a Bridge
  • Via the switch to get better performances
Waht do you suggest?
Thank you
