RBDiscG-5acD unexpected reboots
Hello.
I’ve got a pair of RBDiscG-5acD to build PtP wireless link. But there is very strange behavior: device reboots several times per day without any confirmed reason.
I had tried to change power supply, install UPS, update ROS and RB firmware - no luck.
Log looks like:
May/15/2018 07:57:54 route,debug,event     interface=wlan1
May/15/2018 07:57:54 route,debug,event     status=UP
May/15/2018 07:57:54 route,debug,event     mtu=1500
May/15/2018 07:57:54 route,debug,event Interface change
May/15/2018 07:57:54 route,debug,event     interface=bridge1
May/15/2018 07:57:54 route,debug,event     status=UP,RUNNING
May/15/2018 07:57:54 route,debug,calc Begin calculation
May/15/2018 07:57:54 route,debug,event Update
May/15/2018 07:57:54 route,debug,calc End calculation
May/15/2018 07:57:54 route,bgp,debug Start BGP instance
May/15/2018 07:57:54 route,bgp,debug     AS=65530
May/15/2018 07:57:54 route,bgp,debug     RouterId=хх.хх.хх.2
May/15/2018 07:57:54 route,debug Begin forced redistribution
May/15/2018 07:57:54 route,debug,event Address added or changed
May/15/2018 07:57:54 route,debug,event     local=хх.хх.хх.2
May/15/2018 07:57:54 route,debug,event     network=хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug,event Added candidate route
May/15/2018 07:57:54 route,debug,event     dst-prefix=хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug,event     attributes
May/15/2018 07:57:54 route,debug,event         protocol=CONNECT
May/15/2018 07:57:54 route,debug,event         distance=0
May/15/2018 07:57:54 route,debug,event         scope=10
May/15/2018 07:57:54 route,debug,event         target-scope=0
May/15/2018 07:57:54 route,debug,event         connected-net= address=хх.хх.хх.2/29 interface=bridge1
May/15/2018 07:57:54 route,debug,event         routing-mark=main
May/15/2018 07:57:54 route,debug,event         table=main
May/15/2018 07:57:54 route,debug,event         origin-type=CONNECTED
May/15/2018 07:57:54 route,debug,calc Tag next hop for recalculation
May/15/2018 07:57:54 route,debug,calc     address=хх.хх.хх.1
May/15/2018 07:57:54 route,debug,calc Select route
May/15/2018 07:57:54 route,debug,calc     dst-address=хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug,calc     attributes
May/15/2018 07:57:54 route,debug,calc         protocol=CONNECT
May/15/2018 07:57:54 route,debug,calc         distance=0
May/15/2018 07:57:54 route,debug,calc         scope=10
May/15/2018 07:57:54 route,debug,calc         target-scope=0
May/15/2018 07:57:54 route,debug,calc         connected-net= address=хх.хх.хх.2/29 interface=bridge1
May/15/2018 07:57:54 route,debug,calc         routing-mark=main
May/15/2018 07:57:54 route,debug,calc         table=main
May/15/2018 07:57:54 route,debug,calc         origin-type=CONNECTED
May/15/2018 07:57:54 route,debug,calc Next hop resolved
May/15/2018 07:57:54 route,debug,calc     route=хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug,calc     immediate-address=хх.хх.хх.1
May/15/2018 07:57:54 route,debug,calc     interface=bridge1
May/15/2018 07:57:54 route,debug,calc     dst-address=0.0.0.0/0
May/15/2018 07:57:54 route,debug,calc         protocol=STATIC
May/15/2018 07:57:54 route,debug,calc         distance=1
May/15/2018 07:57:54 route,debug,calc         scope=30
May/15/2018 07:57:54 route,debug,calc         target-scope=10
May/15/2018 07:57:54 route,debug,calc         next-hop= address=хх.хх.хх.1
May/15/2018 07:57:54 route,debug,calc         comment=
May/15/2018 07:57:54 route,debug,calc         origin-type=STATIC
May/15/2018 07:57:54 route,debug Commit prefix хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug Commit prefix 0.0.0.0/0
May/15/2018 07:57:54 route,debug End redistribution
May/15/2018 07:57:54 route,debug Begin redistribution
May/15/2018 07:57:54 route,debug Accept add хх.хх.хх.0/29
May/15/2018 07:57:54 route,debug Accept add 0.0.0.0/0
May/15/2018 07:57:58 certificate,debug start CRL update
May/15/2018 07:58:02 bridge,info hardware offloading activated on bridge "bridge1" ports: ether1
May/15/2018 07:58:02 route,debug,event Interface change
May/15/2018 07:58:02 route,debug,event     interface=ether1
May/15/2018 07:58:02 route,debug,event     status=DOWN
May/15/2018 07:58:02 route,debug,event     mtu=1500
May/15/2018 07:58:02 route,debug,event     status=UP
May/15/2018 07:58:02 route,debug,calc Begin calculation
May/15/2018 07:58:02 route,debug,event Update
May/15/2018 07:58:02 route,debug,calc End calculation
May/15/2018 07:58:03 certificate,debug start CRL update
May/15/2018 07:58:04 interface,info ether1 link up (speed 100M, full duplex)
May/15/2018 07:58:04 route,debug,event Interface change
May/15/2018 07:58:04 route,debug,event     interface=ether1
May/15/2018 07:58:04 route,debug,event     status=UP,RUNNING
May/15/2018 07:58:04 route,debug,event     mtu=1500
May/15/2018 07:58:04 route,debug,calc Begin calculation
May/15/2018 07:58:04 route,debug,event Link up
May/15/2018 07:58:04 route,debug,event Update
May/15/2018 07:58:04 route,debug,calc End calculation
May/15/2018 07:58:06 bridge,stp ether1 learning
May/15/2018 07:58:06 bridge,stp ether1 forwarding
May/15/2018 07:58:08 certificate,debug start CRL update
May/15/2018 09:24:33 system,info cloud change time May/15/2018-07:58:57 => May/15/2018-09:24:33
May/15/2018 09:24:33 certificate,debug start CRL update
May/15/2018 11:07:40 system,info,account user admin logged in from хх.хх.хх.200 via winbox
Have anyone any ideas?
Alex.
Confirm if any script isn’t running
