RBFTC11
Hello
just some info:
I connect it to a remote device, using 1,25Gb LC SM SFP from Mikrotik.
I use then UBNT 24V 0,5A giga POE.
do I need some specific settings? like disabilng auto-neg on the remote device?
Do I need to keep it on auto auto?
I had some issues on with a FTC and two opton WDM SC 1,25 SFP.
one side: RB960 , remote side FTC.
randomly the connection was down. Was a problem of duplex?
I then replaced the FTC with a RB260GS and I disabled negotiation on both sides, and it worked.
