RBGroove A-52HPn Antenna Pattern
Hi Guys,
I looking for the groove 6dbi 2.4 / 5 ghz antenna patter..
I have found only:
2.4Ghz Dipole 5dBi
Can anyone help me to find it?
It will be same as any other dipole
Thansk for the Replay..
i know that, but the dipole 3d radiaton that you post is ideological pattern, if it exit i need the real one..
Thanks in advance!
Hello.
I think it is that antenna
any diagram is idealistic, there are no manufacturer patterns that are based on measurements, like you say “real”. they are all from design only.
network analyser is real and test on anechoic chamber also
ham radioamateur can also do that
