Hello, i want to use a RBGrooveGA-52HPacn as a wireless repeater of another mikrotik metal that i am using as an AP. Im not being able to do it, because the Groove can receive the signal from the AP but it can’t repeat it. I found that in the options when i make the configuration of the new AP of the repeater there is no “setup repeater option”.
The procedure that i’m following to do it is this one:
http://www.itlearnweb.com/2016/10/mikrotik-wireless-range-extender.html
I tried doing it using the Groove as AP and the Metal as repeater and it works. but it would be better if i can achieve it in the first way
So the main question is: can this groove work as a repeater? if not, what am i doing wrong?
