Thank you mates, yes I'm aware of SWR and all those conseguences, this is why I'm asking you here, based on your experience, possible somebody who tested directly this antenna may say that.
Yes you got me, in this case I'm cheap, there are no resons to spend more money in such situation, this is an outside hotspot and useful for external cameras only, which are 2.4GHz only, and it may serve occasionally my friend when moving outside, he hasn't demands to be that fast&efficent as the 5GHz assures.
I've bought this AP second hand, and it will come without antenna, I can say more, I don't want to change the actual situation reducing antenna's dB, risking that may the farest camera wil not more stream as it does before. This place is far to me, so I don't want to go back there after the work is finished.
My goal is only to have this AP working with Capsman in harmony with the ones inside, without all the inconvenience of having 2 different SSID near as it is now, myfriend can live without 5GHz if complicated, as he does now
In case I enable 5GHz, there is any way to check if something goes wrong with the signal? Any parameter can tell TX is suffering? My idea is to set a very low power at the beginning, put my mobile close to antenna and connect it to 5GHz SSID only, then check on my phone how it receives signal, then do traffic and check on router the CCQ, if the values are optimal as they should, chances are antenna is compatible, if not, better to turn that radio off and forget.
Could I easily reduce the 5GHz power to a sefe level by one parameter, or should I specify TX dB for each speed? Which value is the lower and you recomend me?
As RBGrooveGA-52HPacn doesn't now if an antenna is effectlively connected at its first boot I supppose it starts with the both radios off as default, isn't that?
If not, after the first boot I need quickly to turn 5GHz off.. anyway I think if it stays on for some seconds it will not be that dangerous for the TX radio
