RBLHGGR&R11e-LTE6 Upload speed difference
I have installed the above device. Everything works fine except one thing …. Upload speeds. I have never got more that 4-5 mbps when testing from of OR laptop. Here is the strange thing …. I get around 18-23 mbps when I test from mobile phone. I even see that in the graphs from winbox. I was thinking if it had to do something with IPv6 for example but also my computers do get IPv6. Any ideas why the mobile phones can get higher upload speed than the pc or laptop through the SAME network ?
the same network is a key.
In network you have many towers and you should try connect to other’s and check what bts give you what speed.
Not always that automatic one give you a proper speed.
Read about Cell Monitor & Cell Lock feature.
Try the cell mapper webpage to locate your towers.
