RBLHGGRR11e-LTE6 No IP address from EE UK
Hoping someone can help - I have a new RBLHGGRR11e-LTE6 - am just using the basic quick setup - I get a good signal from EE (see provided screen grab), but no IP address and no internet connection. Any help advice on what to do next?
in 3m at google I found that:
EE APN settings
APN: everywhere
Username: eesecure
Password: secure
Authentification Type: PAP
This means you not do it by QuickSet.
Go to Interface > LTE > APN and set that options and try again.
You should contact to EE and confirm what APN and settings you should use for regular LTE Router as MikroTik because I found that settings who are common at internet but I not have shoure they are good for you.
Your APN settings are fine but you must know one very important detail. EE will only provide one IP address, either an IPv4 or an IPv6, not both. If you request IPv4/IPv6 you will get a public Ipv6 address. If you ask for IPv4 only, you will get a CGNATed IPv4 address.
Hope this helps,
Paul.
